2007 key cylinder removal
Old Jan 25, 2025 | 06:32 PM
rhensonsr's Avatar
Default 2007 key cylinder removal
I have a broken key in the cylinder of a 2007 Base. The key reader and clock spring have been removed and from what I understand, the tab is on the top back of the cylinder case. I have pressed, poked, prodded, and cannot find the tab. Can someone supply a photo of exactly where it is located and what type of tool needs to be used? Thank you
Old Jan 26, 2025 | 07:03 PM
is the broken key in the on position? if not you will need to have it rotated to the on position or the key cylinder will not come out. as for the tab get your new key cylinder and you can see exactly what tab it is and where its located.
Old Feb 3, 2025 | 03:34 PM
chris07's Avatar
The tab you are looking for is usually located at the top of the cylinder, towards the back of the housing, as you mentioned.
DonHardy
Dec 3, 2023 09:36 AM
ronsemko
May 5, 2011 06:47 PM
joelfett
Jul 31, 2010 08:13 PM
joefisch
May 22, 2009 08:03 PM
murry
Dec 7, 2007 04:57 PM
