2007 PT cruiser starting issue
Old Dec 16, 2019 | 02:48 PM
Carla Marie's Avatar
Default 2007 PT cruiser starting issue
Had a transmission put in and my car is having issues starting. At first it took a few tries but started now just clicking. I was told I could use a bypass method but I dont know what wire to use because of voltage.. I read you can run from solenoid + to negative battery but it's not a permanent fix. My daughter had a heart monitor put on today and she is pregnant so I am looking for something to start it in case we need to go. Thank you
Old Dec 16, 2019 | 04:55 PM
well first who put the transmission in? how long after this did the hard starting issue happen? if it was just a short time ago why not take it back tot he people how put the trans in and see what they messed up.
Old Dec 16, 2019 | 05:24 PM
I had 2 done actually but the first one was bad so i had to have it towed to a place I use to work at but its over an hour away. So after spending all that money I truly cant afford another tow that far. I know my way around cars a little but this one is stumping me. I tightened nut on starter with green wire and car fired up just a bit ago. Then I went to start it again and same thing. Nothing but clicking check engine light blinks 10 times. I've read so much and it wont throw a code either.
I just read about bypassing but now I am not sure that's the problem
BoostedPT91
Mar 30, 2018 10:03 AM
Joe Pontbriand
Jul 9, 2017 07:06 PM
Dacusb
May 3, 2014 09:05 PM
cpk
Jun 30, 2012 08:19 AM
guss919396
May 29, 2009 09:59 PM
