Battery Warning Light
Old 03-25-2015, 08:58 AM
BD 2001's Avatar
Unhappy Battery Warning Light
The battery warning light comes on when driving and occasionally at start. It usually resets after engine is turned off & restarted. The alternator maintains a 14.2 V charge on the battery when the battery warning light is on.
Is there a known common short in the PT Cruisers electrical system?
I've also read on several forums that the ECM could be the culprit.
Before replacing the ECM would it be worth a try to re-flash my existing ECM?
or Chrysler TSB # 18-007-07. PCM software flashes?
2001 Limited Edition, 66K Miles, Original Owner
Old 04-16-2015, 07:24 AM
BD 2001's Avatar
Since the weather warmed up the Battery indicator light has not come on.
The last 2 days when attempting to start the PT there is just a click and removing the key for a few seconds and making a second attempt the starter engages like no problem occurred.
I'm suspecting a wiring problem in the steering column.
Anyone have a suggestion what should be looked at first???
Old 01-21-2018, 03:02 PM
BD 2001's Avatar
Initially it was a loose battery cable clamp. Once that was resolved the alternator gave out.
Since both have been addressed no further problems.
latreto
18
02-25-2017 10:11 AM
bgeise
09-12-2014 10:38 AM
qbasicer
09-25-2012 02:58 PM
bryant16e
01-15-2007 01:49 AM
rcy
07-25-2006 05:42 PM
Quick Reply: Battery Warning Light
