camshaft sensor
Old Apr 13, 2009 | 05:04 PM
victor8597's Avatar
Cool camshaft sensor
OK HERE THE DEAL MY CHRYSLER PT CRUISER 2002. CAR CUTS OFF AND CHECK ENGINE LIGHT IS ON. MY OBD2 COMPUTER SAYS ITS THE CAMSHAFT POSITION SENSOR SO I REPLACE THAT AND THE CRANK SENSOR SINCE I READ THAT YOU NORMALLY CHANGE BOTH OUT. THEN i NOTICED MY IGNITION COIL WOULD NOT FIRE UP. SO i REPLACED THAT TO CAR IS STILL THE SAME AND OBD 2 STILL SAYS THE SAME. I NEED HELP
Old Apr 14, 2009 | 10:38 AM
Under the camshaft position sensor you will find the target magnets. These sometimes get cracked and need to be replaced. They are what the sensor is looking for. If they fail, you will get the same code as you would if the camshaft position sensor failed.
If the computer gets no signal from the sensor it will not put out a spark, so that is why you are not getting anything from the coil.
Check those target magnets. Failing that, it could be a wiring problem in the sensor circuit.
cdyer11505
20
Jan 24, 2022 12:08 PM
sumncguy
Apr 17, 2012 07:27 AM
manshack_one
Dec 13, 2010 06:59 PM
jjmenard
Sep 6, 2007 05:33 PM
04300special
Aug 13, 2007 09:15 PM
