P0452 - Evaporative Emission System Pressure Sensor / Switch Low Input
Old 12-16-2011, 12:22 AM
PTCrews's Avatar
Default P0452 - Evaporative Emission System Pressure Sensor / Switch Low Input
Hi,
I have a 2007 PT Cruiser that has been throwing a P0452 code every since this shop installed an alternator. I kind of agree with them that what they did could not have caused the issue... However, I have not ruled it out. It also throws a P0340 (Camshaft Position Sensor A Circuit (Bank 1 Or Single Sensor)). My primary concern is the P0452.
Initially, it would throw the code and act up sporadically. It is starting to happen more frequently and additional symptoms are happening.
When the car is acting up, it jerks and hesitates during moderate to heavy acceleration. It does fine with light acceleration. Turning the car off and immediately back on again usually solves the problems. As the condition is worsening, the car has trouble starting now.
The hesitation and jerking during acceleration reminds me of fuel starvation like from a bad fuel pump, but I'm not sure. However, by turning the car off an back on again makes me think it is electrical... bad vapor canister solenoid, connector or wiring???
Has anyone else had this problem?
Thanks!
Old 12-16-2011, 07:39 AM
452 is EVAP leak only not a real gas leak its the vapor from the gas tank used to the engine it ill not affect how the engines runs at all.
The bucking and such is more then likely cam issue at hand.
Old 12-17-2011, 09:15 AM
PTCrews's Avatar
Thanks Chrysler Tech!
Can a bad camshaft position sensor be temporarily corrected by turning the car off an back on again?
Thanks again!
Old 12-17-2011, 01:20 PM
depends if the sensor is in a good mood or not
Old 12-21-2011, 09:22 PM
PTCrews's Avatar
OK... Sure seems like the camshaft position sensor. I cleared all of the codes. P0452 was thrown twice tonight. No hesitation at all.
Old 08-10-2012, 07:37 PM
JayDee240's Avatar
Any solution to the P0452 code?
Old 08-12-2012, 10:29 PM
PTCrews's Avatar
Still have not solved the P0452. The weird thing is, the P0452 code had not been thrown in a long time. Right after I replace the camshaft sensor (for P0340), it started coming up again. Could be just a coincidence.
Old 11-02-2012, 05:20 AM
LucianaHardin's Avatar
Old 05-04-2016, 11:40 PM
docmopar426's Avatar
where is the evap switch located? my pt cruiser is showing a p0452 code intermittently.
alaskanJK
02-06-2021 09:00 AM
jeepdaddy65
10-28-2013 03:12 PM
Lemaigre
09-08-2011 07:51 AM
stormin_norm
10-09-2007 02:11 PM
rmichels
07-02-2007 08:54 PM
Quick Reply: P0452 - Evaporative Emission System Pressure Sensor / Switch Low Input
