Dealer wont fix my car, Shops can't...HELP!
Old Aug 28, 2024 | 12:00 PM
Tprehm's Avatar
Exclamation Dealer wont fix my car, Shops can't...HELP!
Hi! I'm trying to sell my fathers car. It's a 2006 PT Cruiser Touring with 36,000 Miles on it. It's just been sitting in the garage as my dad has been too old to drive it now for a while. The check engine light came on and I took it to the dealer and the dealers all wont work on cars this old. I took it to a random mechanic and they said that it was a problem with the computer that only a dealer can fix. So no one is willing to work on it. Any thoughts on what I should do?
Here's the problem with the car from the mechanic
U0100 Lost Communications with ECM/PCM
U0101 Lost Communications with TCM
Starter does not engage properly. Performed Global reset. When engine is running codes are stored. When engine is off and key is on codes are active.
Old Sep 2, 2024 | 01:09 AM
passionfruit's Avatar
Have you considered selling it as-is and being upfront about the issues?
Old Oct 6, 2024 | 07:45 PM
rhensonsr's Avatar
Default Computer
U codes associated with check sum errors usually cannot be repaired. I have run into 3 of them that I replaced the computer and it fixed the problems. Hope this helps someone.
Old Oct 7, 2024 | 09:08 AM
carlraphael's Avatar
Default Need to find the right shop
Many shops have aftermarket places they go to swap computers. You just have to find the right shop to swap out your old one.
RichB
Jan 2, 2024 02:24 PM
voncruiser
Nov 13, 2019 03:55 PM
02caltaco
Dec 17, 2016 04:04 PM
STEPHDONYA
Sep 16, 2011 12:10 PM
OfPirateMind
Nov 3, 2009 05:47 PM
