Look at buying 2001 PT Cruiser
Old Nov 19, 2018 | 06:23 PM
purplepuller's Avatar
Default Look at buying 2001 PT Cruiser
Looking at buying a 2001 PT cruiser with broken timing belt. Will it have piston or valve damage? Have 2004 sebring (2.4)and timing broke on me last year changed belt and all was fine.
Old Dec 16, 2018 | 06:19 AM
Bought car and installed new timing belt along with all new belts water pump and tensioners. All is fine.
Old Dec 28, 2018 | 03:49 PM
Ktucker2006pt's Avatar
Default Valve damage
these motors are interference motors with means when belt breaks valves collide with pistons and bend so yes you will have an issue. I don't care if it was at idle or 5000 rpm there will be damage
Old Dec 28, 2018 | 09:05 PM
Replaced Belt on the Sebring in May of 2017 and have put over 20000 miles on it since. And the PT is running fine. No miss, runs like it should. Pretty sure these engines are noninterference.
cnc
Mar 17, 2015 12:24 PM
Chryslr610Cordo
Sep 20, 2014 11:46 AM
jakemary
Nov 15, 2008 10:52 AM
May 1, 2006 01:52 PM
snoopycruiser
Jan 7, 2006 04:20 PM
