2004 PT Cruiser Cuts Out, Engine dies for no reason
Old 11-10-2018, 07:19 PM
samy's Avatar
Unhappy 2004 PT Cruiser Cuts Out, Engine dies for no reason
At first, my first suspect was the fuel pump, I replaced the fuel pump and the still problem.
The engine light goes on and the engine cuts off, the codes were P0038 & P0032, I crank the engine and Immediately engine go on, It's running well some days and after the problem back again. I need help.
2004 PT Cruiser 2.4L non turbo.
BR
Old 11-11-2018, 04:19 AM
BiliTheAxe's Avatar
02 sensor heater shorting out.
Check wiring harness for damage or shorts.
It could also be a damaged heater circuit within an O2 sensor, or a defective ECM.
If wires look fine, try replacing the O2 sensors. They should be replaced every 40,000 miles anyway, and almost no one ever does at least till they have failed.
Petar Å ank
09-23-2018 04:18 AM
jacmates
11-07-2015 10:55 AM
trossx1
09-14-2011 12:04 PM
05-01-2006 01:52 PM
QuickSilver05
04-03-2006 03:50 PM
Quick Reply: 2004 PT Cruiser Cuts Out, Engine dies for no reason
