P0300 & p0339 codes troublehooting help
Old Jun 1, 2024 | 08:42 PM
Rossk's Avatar
Default P0300 & p0339 codes troublehooting help
Hi, i have p0300 & p0339 codes which i cannot solve.
The following parts have been replaced:
1)ignition coil, wires, plugs
2) crank sensor (× 3), cam sensor
3) throttle body sensor
4) pcv valve
Compression has been tested and all cylinders were good
Symptoms:
Starts and idles fine but will not go over 2500 rpm's without jerking and sputtering. Can drive and will shift and pick up speed to 60 mph as long as i dont rev above 2500 rpm.
check engine comes on and stays flashing
Pulling my hair out with this problem. Don't know what else to try. Any/ all help appreciated
thanks Rossk
rosskennedy1960@gmail.com
Old Jun 2, 2024 | 05:53 PM
year make modal engine size ?
Old Jun 3, 2024 | 01:40 PM
Rossk's Avatar
2007 pt cruiser base model 2 4 litre engine non-turbo
Old Jun 3, 2024 | 08:10 PM
What brand Crank sensor did you use? and spark plugs what brand?
Old Jun 3, 2024 | 09:22 PM
Rossk's Avatar
Crank sensor was a Napa Eklin brand
plugs were Champion (oem)
Old Jun 4, 2024 | 06:19 AM
FIREM's Avatar
Use only OEM Mopar cam and crank sensors. Aftermarket tend to be problematic in Chrysler products.
YouTube ScannerDanner How to test crank sensor with a volt meter
This is a great video for testing both cam and crank sensors easily with a simple volt meter
jac20500
Jun 3, 2019 12:34 AM
J0080
Aug 29, 2018 11:45 AM
pauley
Aug 16, 2014 01:00 AM
01 blues
Aug 21, 2010 12:23 PM
jdguy
Dec 28, 2008 06:16 PM
