PCM Swap
Old Jul 19, 2021 | 02:37 PM
skidooguy68's Avatar
Default PCM Swap
I have 2 08 Cruisers, one has been hit pretty hard, the other is immaculate. The good one has a bad PCM, the other ran fine until ya know....
Can I use the PCM from the one 08 in the other without a huge issue? Will I need to do anything VIN wise or Key wise? Can I swap the ignition with the key and not need a reprogram?
My wife really enjoys the car, and happy wife, happy life.
Thanks for the help.
Old Jul 20, 2021 | 08:39 PM
well need to swap pcm, Keys key tumblers, Skim module and door key cylinders for them all to work correctly.
Old Jul 21, 2021 | 04:21 AM
Will the VIN need to be programmed or will it remain as it is? Im in NY and our inspections sometimes do a VIN match between the PCM and the registration. They may not match if the vin is in the PCM.
Old Jul 21, 2021 | 08:38 PM
no they will not match the cars original vin
Old Jul 22, 2021 | 07:26 AM
Thanks for the info. Am I understanding correctly, the pcm stores the vin? So if I swap the parts the vin displayed in the scan tool will be of the swapped in pcm?
Old Jul 22, 2021 | 10:39 AM
Mileage is also stored in the PCM. That may cause a discrepancy on your title if it appears to be "rolled back". If they're close, nobody will probably ever know or care. For about 200 bucks or so, you can replace your PCM on an exchange basis. There are services on the internet that will do that. You send your VIN and mileage to them, they send the replacement PCM. You swap it out and send the old one back to them. Very easy.
Here's one such service:
https://carcomputerexchange.com/
There are others.
Old Sep 9, 2021 | 10:16 PM
GP49's Avatar
There are services that will flash an existing PCM with the VIN and odometer mileage so it will work with the keys that function with the car where you are installing it and match the vehicle's mileage. "Myckeee" on EBay mainly sells rebuilt PCMs but he can do it to yours, assuming it is working. No warranty on the existing PCM, though...it would be your used one, so I think that's understandable.
Gorgon
11
Jan 3, 2020 07:31 PM
stuuupid1
9
Mar 27, 2015 11:32 AM
mpd2416
Nov 16, 2014 09:48 PM
dstevens49
Aug 27, 2014 07:57 AM
indianajim
Apr 8, 2011 04:42 PM
