Windshield wipers inop
Old Mar 26, 2021 | 07:18 PM
IMPALADAKID's Avatar
Default Windshield wipers inop
Hello
So we have a 2007 Touring Convertible. The wipers do not work on any speed. I pulled the plug and with a test light checked the connections as my wife worked the multifunction stalk. The power moved from one pin to the other pin as she moved it from low to hi, and I got power. So I checked the motor with a multi meter, and got continuity. I put 12 volts directly to the motor, and it worked. So the wiring has power, and the motor works. Is one of the other pins a signal from the TIPM? Not too sure. Seems like there is power at the plug, the multifunction switch seems to be working, the motor works, and the windshield washer works from the switch. Just not the wipers. I did clean the grounds, and used dielectric grease.
How can I diagnose the TIMP as the problem?
Old Apr 23, 2021 | 01:17 AM
Saturn19's Avatar
Have you checked the rubber bushing that holds the wiper arms going to the motor? The bushings might be no longer holding onto the arms.
Old Apr 24, 2021 | 08:23 PM
Solved. Bad ground
carguy1212
Sep 5, 2017 01:06 AM
Christopher Kleiner
Dec 19, 2014 01:15 PM
wesman
Jan 4, 2014 05:16 PM
jhoward7414
Feb 7, 2012 07:03 AM
webbch
Jan 4, 2007 09:11 PM
