01 t&c cranks no run
Old Nov 21, 2011 | 10:20 AM
Then u have a computer issue or a wire issue cam or crank sensor. Issue. I don't take personal calls sorry I can't open that door I already get calls and emails from all over the world
Old Nov 21, 2011 | 11:01 AM
TNtech's Avatar
Are you getting communication with the PCM at all? I guessing some dingaling at the dealer just saw that and threw a PCM at it.
Old Nov 22, 2011 | 11:42 AM
hefmarkie's Avatar
yes i have a data stream from the pcm
Old Nov 22, 2011 | 12:13 PM
TNtech's Avatar
What does your cam/crank sync look like? Give it about 15 secs of cranking see if you see one of them drop out. I want to be clear on something first...is the new PCM they put in still in the car?
Old Nov 22, 2011 | 12:57 PM
  #15
hefmarkie's Avatar
yes the replacement pcm is the one in the vehicle now. my scanner only shows rpm and it stays at 0 during crank
Old Nov 22, 2011 | 01:07 PM
  #16
hefmarkie's Avatar
my books here bypass the 01/02 yr mods and dont show where the crank sensor is can u let me know the loc of that sensor
Old Nov 22, 2011 | 01:36 PM
  #17
driver side where the trans and engine meet
Old Nov 22, 2011 | 02:06 PM
  #18
hefmarkie's Avatar
there are two paramaters out of range to go with the codes stored
tps reads 100% and unplugged it still is @ 94
cts reads -40 @59f outside
Old Nov 22, 2011 | 11:11 PM
  #19
TNtech's Avatar
Sure looks like you have 5V reference circuit issue. What the exact problem with it is, there is no way I can tell you from here. Lots of meter probing.
Old Nov 23, 2011 | 09:17 AM
  #20
hefmarkie's Avatar
i know it would take time and alot of effort for anyone to help me with this veh. wish i was able to find a pay for tech support that was credible so i had the info make this veh run again because i know i can
