02 Chrysler T/C Transmission Leak
Old Feb 25, 2007 | 12:30 PM
Daryl Baines's Avatar
Default 02 Chrysler T/C Transmission Leak
I have a Chrysler 02 T/C the outside temperature was 29 degrees and the cold weather lasted for about 4 days in Florida that is cold but my question is I noticed 2 oil spots on the driveway and found it was coming from the transmission pan could this cold weather have effected the pan gasket should I have it replaced or will the warm weather swell the seal back to normal I guess this is wishful thinking mileage is not ready for a fluid change yet.
Old Feb 25, 2007 | 03:49 PM
Default RE: 02 Chrysler T/C Transmission Leak
have u done service to the tranny yet??? an 02 u should have 2 times already 30k each. Trannt fluid is still an oil based oil like engine oil it will break down over time . The pan is sealed up with ATF RTV
Old Feb 25, 2007 | 04:38 PM
Yes I did 2 fluid changes. I had a Dodge Caravan that did the same thing in cold weather and did not solve the issue and the leak would go away in hot or warm weather.
farmerbob02
Apr 13, 2011 12:04 AM
redfin123
Dec 2, 2008 08:38 AM
billbon8
Sep 1, 2008 12:49 PM
hammerdown72
Apr 5, 2008 07:10 PM
fyrepower
Nov 16, 2007 07:44 AM
