'02 Grand Voyager immobilizer problem
Hi,
My 2002 Grand Voyager will not start.
It was OK two days ago but yesterday we had some low temperatures (-11 deg C) in the UK and this morning there appears to be a problem with the immobilizer.
When I put the key in the ignition and turn it to the ON position all of the dash lights work OK, but the multifunction indicator light flashes a few times and the indicator/turn signal light flash twice.
The engine will not start - I get a continuous clicking sound and all of the dash lights flash.
I've tried both keys with the same result.
Also sometimes whein I turn the key the A/C display comes on, other times not. If the A/C display is on there is no time display on the radio, if I turn the radio on the A/C display disappears.
I've tried disconnecting the battery but no change.
My obd2 code scanner cannot retrieve any codes - it indicates a communication error.
I've tried getting an error code from the odometer but nothing shows.
Any ideas anyone?
Thanks.
John
Any ideas anyone?
Thanks.
John
I had exactly the sam problem this morning. -15 deg C in Sweden. Very week starter engine and then no starter engine at all. Only a continuous clicking sound (ca 3-4 clicks per second). I tried to jump start the engine with cables from my other car. No response, just that annoying clicking.
I have now removed the battery at recharge it indoor (it is very cold now outside...).
Let's hope it will work.
Any other ideas?
Any other ideas?
Fredguy
Dec 10, 2009 02:39 AM
Guy_laister
Mar 18, 2008 02:19 PM
GO PATS
Jan 1, 2007 07:13 PM
