03' Air Bag Light On
Old Nov 27, 2015 | 02:47 PM
Rangr90's Avatar
Angry 03' Air Bag Light On
03' Air Bag Light On. Can someone tell me why and what to do?
Rangr90
Old Nov 27, 2015 | 10:39 PM
i can tell u what to do but why its on no i cant.
What you do is visit a shop pay them to hook a vary expensive scanner up to the car and get teh codes for the air bag system
Old Nov 28, 2015 | 04:11 AM
andyb2000's Avatar
Search the forums my friend, there are many posts about airbag lights coming on and various things to check that are the easy ones.
Unfortunately though the only sure way is to get the SRS code scanned which isn't easy or cheap.
As I just mentioned on another post though, clearing the light is easier, if you find and fix the fault, at next ignition on the light will go out, so you don't need to take it to dealership to get the light put out again after the fix.
I'd say first port of call, check the seatbelt pre-tensioners (check that both seat belt insertion points are the same height, if one is lower then it's probably fired), then check the cable spaghetti mess under the seats, the connectors there can sometimes go loose and cause the fault.
After that it's onto the more complex things so better to get it scanned to work out where to focus on.
Old Nov 28, 2015 | 10:10 AM
Rangr90's Avatar
About 4 days ago i sprayed silicone on the driver's seat belt female connector becaused it was hard to connect and disconnect the seat belt which helped a lot.
Is it possible that is why the light came on 4 days later?
Rangr90
Old Nov 28, 2015 | 11:03 AM
andyb2000's Avatar
Hi Rangr90,
That's a possibility, when you say silicone, was it silicone grease spray and a conductive/non-conductive variety?
Inside the seat-belt receptacle there is a sensor to detect if the belt is fastened (it'll also illuminate the dash light if the seat sensor detects somebody sat in the seat but without doing the belt up. Does that light illuminate when it should?) and it is possible that the spray inside has caused a fault to show up.
If you have one, perhaps try an air can to blast inside it, or try and dry it up a little, it might just save an expensive trip to the garage for you!
Old Nov 28, 2015 | 01:47 PM
REM the 5 finger tool !
Old Nov 28, 2015 | 02:27 PM
Rangr90's Avatar
I just ran the passenger seat belt up and down and now the light is out. My wife had the belt on when the light started to come on .
It's all her fault.
Thanks for all the help guys so far it is ok.
Rangr90
dblcruzin
May 3, 2008 09:21 AM
automd
Feb 11, 2008 09:46 PM
debbie210363
Jan 24, 2007 07:48 PM
jmazza
Dec 8, 2006 07:18 PM
jmazza
Sep 15, 2006 07:57 PM
