03 t & c jumping speedo only in gear.
Old Jul 24, 2017 | 09:18 PM
Jeremy Ivy's Avatar
Default 03 t & c jumping speedo only in gear.
ok So I'll keep this short. Started going into limp mode. Checked codes and it showed output sensor so I replaced the output sensor and cleared codes and thought everything was good. Drove roughly 100 miles and then outta no where there it is....back.
In park it will set at 0 and not bounce or change.
Any gear the typical jumps are up to 20mph and sometime randomly jumps to almost 120.
The part that I don't get the most is once I start rolling...roughly 5mph the speedometer doesn't jump at all it has zero issues.
So to me it was noise or a short that happens when the motor turns from being put into gear.
But I have had someone watch the speedometer and I have lifted and wiggled the wires all over the place without any jumps while sitting in park.
Just looking for advice, a way to test the TCM or someone who had this issue.
oh also I supplied the TCM with power straight from the battery. I've also replaced the pigtails and wiring to the input and output sensors with no change. I'm holding a 13.65-13.75 in voltage. Has a good strong battery
video
https://youtu.be/htW7fkQ3xfI
Thanks Jeremy
Old Jul 25, 2017 | 12:12 AM
Raptor 07's Avatar
The output speed sensor is the signal source for the speedo. From your description you changed it then this speedo jump cropped up. Sounds more like a bad sensor or connection at the sensor.
Old Jul 25, 2017 | 08:21 AM
Jeremy Ivy's Avatar
Default Problem
Old sensor was doing the exact same thing. Which is why the limp mode and why I replaced it.
almangar
Sep 22, 2012 06:59 AM
Confidance
Apr 23, 2012 08:40 AM
steviemac74
Nov 25, 2011 04:04 AM
goat1966
Dec 8, 2007 02:55 PM
