06 T&C touring gas gauge/fuel sensor problem
Old Jan 17, 2007 | 11:47 PM
kb's Avatar
kb
Default 06 T&C touring gas gauge/fuel sensor problem
We purchased a new 06 t&c touring model in may, approximately 3 months in to our ownership we started having an intermittent problem w/the gas gauge, here’s a description of the problem including what leads up to the problem occurring, we’ll fill the van up w/a full tank of gas, after driving approximately 30 miles the gauge will go from almost full to empty, the overhead digital read out will quickly count down to zero, our low fuel indicator will go on, and the malfunction indicator light will also go on. On one occasion the gauge intermittently went up and down for hours. However this is rare, it usually only lasts for a few minutes. I’m fed up with the service at our dealership, we’ve had them look at the van 2 times while the problem was occurring, it's hard getting it in there considering it usually only lasts for a few mins. The dealership is telling us that this is a software issue, however as of yesterday they’re still waiting forthis supposed “software” update from the mfg. I'MSO FED UP!!!!We're going to start the process to have the car deemed a lemon.[:@]
has anyone heard of this problem????????
Old Jan 18, 2007 | 01:50 AM
Default RE: 06 T&C touring gas gauge/fuel sensor problem
ok buddy check this out it came out today its a software update for your year van if u fall into the build date listed below I can either run the vin and find out for u or u can call the dealer back up and have them check it for u.
NUMBER: 18-002-07
GROUP: Vehicle Performance
DATE: January 17, 2006
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 18-030-06, DATED
OCTOBER 26, 2006 WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL
REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE THE ADDITION
OF 2006 MODEL VEHICLES.
THE DRBIII® FLASH FILES FOR THIS BULLETIN ARE AVAILABLE ON
DealerCONNECT.
WHILE THE FILES ARE CURRENTLY AVAILABLE FROM THE INTERNET FOR ALL
MARKETS, FOR MARKETS OUTSIDE OF THE UNITED STATES AND CANADA, THE
DRBIII® FLASH FILES AND REPROGRAMMING INSTRUCTIONS WILL ALSO BE
AVAILABLE ON ITIL/ISIS DVD APRIL, 2007.
SUBJECT:
Flash: MIL Illumination - P0461-FUEL LEVEL SENSOR #1 PERFORMANCE
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
MODELS:
**2006** - 2007 (RS) Town & Country/Caravan (Includes International
Markets)
**2006** - 2007 (RG) Chrysler Voyager (International Markets)
NOTE: This bulletin applies to RS models built prior to October 2, 2006 with an R in
VIN position 11 (MDH 1002XX), October 9, 2006 with a B in VIN position 11
(MDH 1009XX), or RG models built prior to October 2, 2006 (MDH 1002XX)
equipped with a 3.3L or 3.8L engine (Sales Code EGA, or EGH)
SYMPTOM/CONDITION:
The vehicle operator may experience MIL illumination with no other symptoms. This may
occur intermittently and be difficult to duplicate. When the technician evaluates the vehicle,
diagnosis may lead to incorrectly replacing the fuel pump/sending unit module.
Old Mar 21, 2007 | 01:59 PM
kryslim's Avatar
I presume your vehicle is a Stow N Go...no matter what it is, please change your vapor, canister...that should be your problem...
Old Mar 21, 2007 | 02:48 PM
KRYSLIM what are u talking about dude?? U are wanting some one to replace a part for a computer update?? do u even know what a vapor canister is or does?
Old Mar 21, 2007 | 11:17 PM
kryslim's Avatar
You are not the only Chrysler guy here...Chrysler Tech...
Old Mar 22, 2007 | 03:04 AM
then tell me what does a vapor, canister have nething to do with this mans prob?
Old Mar 22, 2007 | 10:44 PM
ace's Avatar
ace
Well i know we have replaced alot of fuel pumps at our dealership we now have about 9 in stock at all times in case of a rush on them. Not sure if this helps at all but being its a new car you should not have to buy anything though
lkwhalen68
Nov 12, 2013 08:36 AM
gilesprincess
Feb 25, 2013 05:16 PM
PacificaBEW
Aug 9, 2011 11:41 AM
96BTC
Sep 27, 2010 10:29 PM
Sofargone
Aug 16, 2005 09:14 PM
