'07 T&C 3.8 dies
Old Feb 2, 2010 | 02:13 PM
jblueguy's Avatar
Default '07 T&C 3.8 dies
Newbie. Thank you in advance. I have an '07 T&C touring with a 3.8l. My wife said she was driving along, minding her own business, and it died. She said the dash had no lights, and it just stalled. She coasted to the side of the road, restarted it and off to work she went. This is our baby-hauler, and Ohio winters can get cold. I cant have her getting stranded with the kids. Please help. Thanks
Old Feb 2, 2010 | 02:58 PM
22chrysler's Avatar
wont delete
Old Feb 12, 2010 | 08:52 PM
jblueguy's Avatar
well thanks for the smackdown. don't I feel welcomed. Is there a typical problem that results in these symptoms?
Old Feb 12, 2010 | 09:50 PM
ultimateDIY's Avatar
I'd take it to Advance or Autozone and have them pull the code. If you have a haynes manual you can probably do the key thing and make the engine light blink. That would be a start. Sounds like electrical though, like a loose ground wire.
Old Feb 13, 2010 | 03:48 AM
Jacob25crd's Avatar
I agree with ultimateDIY. Getting the code is a good thing to start. You can get the error code yourself. It will display after you switch the contact on-and off (do not start) about 3 times in 5 secs. This will only tell you a 5 digit code, not even the time it happened, for other details you need a scan tool.
Old Feb 13, 2010 | 07:40 AM
22chrysler's Avatar
wont delete
Old Feb 13, 2010 | 09:47 AM
Midnight 85's Avatar
Administrator
Badgering new members and sarcastic off topic posts will not be tolerated. I've had too many complaints. Sorry for the inconvenience, jblueguy.
Old Feb 13, 2010 | 09:58 AM
jblueguy's Avatar
I now have a little more information. My wife told me this morning that the van died again. She said that she bumped the key as the car was parked but running. She vaguely remembered that she may have bumped the key the first time this occurred. Chrysler22, you mentioned a key-bumping issue. Is there a common problem with the ignition assembly that you are aware of? Or anyone else? With about 57000 miles, the only work that has been done has been oil changes, tires and some warranty work done by a dealer. The point of that is, no one has been rooting around loosening ground wires--that I know of. Thanks all for your help.
Old Feb 13, 2010 | 06:48 PM
if it was a key issue u would see all the lights and gauges go dead like u would if u were to turn the key off then back on.
Old Feb 13, 2010 | 10:53 PM
jblueguy's Avatar
She noticed that the gas gauge showed empty although she knew it wasn't and the dash was dead. Another time the lights inside and out got brighter for a second then back to normal. Man I hate electrical problems.
dlfjc
May 24, 2013 07:16 PM
d79angel
Oct 6, 2012 07:15 PM
crash1972
Jun 14, 2011 10:15 AM
DJ_Playing
Apr 22, 2006 03:58 PM
Mar 26, 2006 11:53 PM
