14 town and country transmission fluid capacity
Old Mar 9, 2022 | 08:53 PM
Scottel's Avatar
Default 14 town and country transmission fluid capacity
I had a cooler line blow while driving and lost all my fluid. I fixed the line and I have put 11 quarts of fluid in so far and its not even hitting the dip stick yet is this correct or am I missing something. Does any one know who much it will hold
Old Mar 10, 2022 | 08:20 AM
ggoose's Avatar
What are you using to measure the fluid level and how are you measuring it? The service fill for the 62TE, trans pan drop and refill, is around 5.5 qts. The total capacity of the 62TE is 9 qts.
Old Mar 10, 2022 | 08:54 AM
You must have the engine running to measure the transmission fluid.
Old Mar 10, 2022 | 09:23 AM
Scottel's Avatar
The van is running in neutral, level and I am using i dip stick to measure by mm and temp per factory guild lines. I have no leaks and don't now cause I blew the line at 70 miles per hour if that pushed out more fluid than it should have.
Old Mar 10, 2022 | 09:25 AM
Scottel's Avatar
Is the size of the cooler and lines playing a factor?
Old Mar 10, 2022 | 09:28 AM
Scottel's Avatar
I took it on a short test dive last night to make sure I had the transmission oil hot enough and then checked it. It acted like it was short shifting like it was still low on fluid I am going to keep adding 1/2quart at a time and make sure I don't overfill tell I get the reading I should have. I'll keep everyone up to date on how much it takes
Old Mar 10, 2022 | 10:24 AM
But you still need to have the engine running.
Old Mar 10, 2022 | 10:42 AM
Scottel's Avatar
I am checking it with the engine running and in natural i just put the 13th quart in and I got it to the low end of my mark I think 35 mm I am going to take a test drive now and check it again when I get back
Old Mar 10, 2022 | 10:57 AM
Scottel's Avatar
13 quarts is what it took to fill
Old Mar 10, 2022 | 11:07 AM
Is that what we called 26 pints?
user 697820823
Sep 13, 2021 10:19 PM
br674
Aug 7, 2009 09:30 PM
toubis
Oct 22, 2008 06:53 AM
sebring01
Aug 27, 2007 06:07 PM
sebringpilot
Nov 7, 2006 03:52 PM
