2004 Sebring convertible motor fluid
Old Sep 12, 2021 | 12:29 PM
user 697820823's Avatar
Banned
Default 2004 Sebring convertible motor fluid
Can I use power steering fluid in my top motor? Just a bit to top it off as it is getting sliw going up (again). No signs of leaking though??
Old Sep 12, 2021 | 01:53 PM
Power steering fluid or transmission fluid would be fine. There must be some reason it's losing fluid. It shouldn't. Inspect the lines, couplings, cylinders carefully.
Old Sep 12, 2021 | 02:29 PM
ggoose's Avatar
For '04, Dexron is the power top fluid. It is a different fluid from ATF+4 which is the trans fluid and power steering fluid for '04
As dcotter noted, the only reason it would be low on fluid would be if there is a leak. The leak would be evident by an oil stain or puddling by the pump or the cylinders.
Old Sep 13, 2021 | 10:19 PM
If the top is slow going up, make sure the mechanism isn't binding.
mrls430
Mar 27, 2024 05:14 PM
hankwells
Nov 11, 2022 10:47 AM
tasxfire
Dec 20, 2019 04:36 PM
joel63084
May 9, 2014 02:25 PM
