1997 Plymouth Grand Voyager P/S pump ?
Old May 18, 2011 | 12:32 PM
Mechnob's Avatar
Post 1997 Plymouth Grand Voyager P/S pump ?
I have a 1997 Plymouth Grand Voyager 3.3L with air that needs the power steering pump replaced. The question is how do you get the old one off in the tight space that there seems to be under the vehicle. Any tips will be much appreciated. I am new to forums and doing my own service to my vehicles.
Old Aug 5, 2011 | 09:25 PM
pappadadda61's Avatar
I got the same problem with the exception of the pulley also came apart after replacing the belt tensioner. Someone hopefully will answer cause help is definitely needed here.
Old Aug 6, 2011 | 12:39 AM
buy a service manual it will walk u through it
Old Aug 9, 2011 | 07:54 PM
Mechnob's Avatar
You have to move the passenger side drive shaft out of the way to remove the p/s pump. There is no need to buy a manual. Make sure you put a pan under the transmission to catch the transmission fluid.
Darth Menace
Feb 19, 2016 09:16 PM
tat@marshall
Oct 4, 2010 12:33 PM
plymouth speeder
Jul 31, 2010 08:11 PM
plymouth speeder
Aug 18, 2009 02:23 AM
gareth111278
Aug 4, 2008 01:16 PM
