1998 T & C Leak Detection Pump Code
Old Oct 8, 2015 | 11:16 AM
randy4golf's Avatar
Default 1998 T & C Leak Detection Pump Code
Got a P1495 and P1494 code indication my leak detection pump may have failed. Does anyone know where this pump is located on the vehicle?
Thanks,
Rando
Old Oct 14, 2015 | 05:57 AM
Vonhofinvule's Avatar
Hi, If you look under the drivers side just under the steering gear if I remember correctly you should see a cast aluminum plate, Its under there. However, I'd also suggest doing a vacuum test on the entire system because leaks elsewhere can sometimes generate the same codes.
Old Oct 14, 2015 | 07:01 AM
randy4golf's Avatar
Default May be the PCM?
Thanks for the reply. That was very kind of you to try and help. I will look at that issue today when I get home. I had some suggest it was by the gas tank and some suggest it was up front so I was trying to narrow my search. I was getting a battery lite previously which I traced back to the PCM. After replacing the PCM with a rebuilt one the battery lite issue went away but the LDP issue arose. I still have the old PCM so I may just put it back in and see if the LDP code goes away. Anyway, I'll keep you posted on what I find and thanks again for your help.
Rando
Old Oct 21, 2015 | 08:04 AM
randy4golf's Avatar
Default Weird
I cleaned up the contacts on the original PCM and put in back in the van. All problems went away. No codes, alternator charging, working like a champ. This has been a weird one but at least it has had a happy ending. Thanks to all for helping with your input.
Rando
rockrat
Jan 22, 2012 05:21 PM
bubbaisthebest
Oct 9, 2011 10:12 AM
firesice18
Apr 21, 2009 09:27 AM
dkeshish
Nov 15, 2007 04:08 PM
Interceptor 2.7
Jul 26, 2006 02:02 AM
