1999 2.5TDI Voyager. Fuel Problem?
Old Sep 17, 2008 | 10:45 AM
TonyQuinto's Avatar
Default 1999 2.5TDI Voyager. Fuel Problem?
Hi from the UK. I have a 1999 2.5tdi Voyager. Done a lot of miles 208,000, but very few problems, except every so often when driving if I come off the gas quickly and touch the brake pedal the engine cuts out. I simply turn off the ignition and it starts again without any problem. It has been to the local chrysler dealership who say it is to do with the fuel management system which will need replacing at a cost around £500.00 !!!!!! Has anyone out there had the same problem with the suggested dealership cure, or are there any other suggestions as to a cure. Many Thanks TonyQuinto
Old Sep 20, 2008 | 05:48 PM
Merlin's Avatar
Default RE: 1999 2.5TDI Voyager. Fuel Problem?
Hi Too little info, do you have the fault codes the dealer pulled? or what they want to replace?
cj4
Cirrus & Breeze
Jan 3, 2014 11:42 AM
kelcan72
May 26, 2013 04:52 PM
vinspe
Cirrus & Breeze
Sep 8, 2011 01:41 AM
rogerroger
Mar 24, 2011 05:44 PM
eddy.crouch
Nov 25, 2008 02:01 AM
