2.5crd voyager oil pump install problem.HELP NEEDED TODAY
Old Jun 7, 2016 | 07:54 AM
imtattoo80's Avatar
Default 2.5crd voyager oil pump install problem.HELP NEEDED TODAY
Hi . i took off and put back oil pump but now car vibrates. What position must be pistons and oil pump weights. Please reply asap.
Attached Thumbnails 2.5crd voyager oil pump install problem.HELP NEEDED TODAY-p1020255.jpg
Old Jun 7, 2016 | 12:55 PM
imtattoo80's Avatar
Got sorted. piston number 1 must be all the way up and balance shaft weights must be down.
Old Jun 7, 2016 | 01:00 PM
That's good to know. Thanks for posting.
Old Jun 7, 2016 | 03:09 PM
A case of fitting replacement pump with gears in position as pump coming out. Is there any marks on the pump gear wheels or is it only done by piston 1 at TDC.
Old Jun 7, 2016 | 05:19 PM
imtattoo80's Avatar
dont know about markings. Only i found was that piston 1 must be TDC ..next of starter motor is even hole for special tool that will line up with hole on flywheel. but it has plastic cap and i could not get it open..too stuck. I tried to get best TDC by looking from bottom of engine into crankcase..
But these balancing shaft weights have a holes on them,,you can see them from picture i added ..and balancing shaft housing has holes at the bottom as well...These are for special tool...i just used same size wire..done same job.
Car is running again and no vibration anymore....that caused by this.
Old Jun 8, 2016 | 02:45 PM
Good job and for anyone doing the job to remember.
Darth Menace
Feb 19, 2016 09:16 PM
uvan
Oct 25, 2011 12:57 PM
Yodastoe
Feb 1, 2009 10:32 AM
opk
Cirrus & Breeze
Jun 18, 2007 06:44 PM
Dec 5, 2004 02:56 PM
