2001 T&C 3.8 all wheel drive limited starter bolts
Old Dec 15, 2010 | 08:31 AM
b_ron007's Avatar
Unhappy 2001 T&C 3.8 all wheel drive limited starter bolts
alright, first time here guys. I'm going crazy trying to figure out where and how do i remove the top starter mounting bolt. The bottom bolt seems easy, but i'm stumped on the top bolt. I can see the top one i think, it has two wires attached to it, 13mm nut holds them on.......but, once that nut is off, is that another nut or bolt right after i pull the two wires off? and if soo, is it from the same side, or do i go from the other side? if the other side, i can't imagine how i would get to it. all the manual says is to remove the two starter mounting bolts.
I searched the net all over, and seems i searched this fourm too. Please help me!
I have 185,000 on the van and have been having intermitent starting issue. its new battery, and it seems to me the selonoid is craping out. Bought the van used 2 years ago.
thanks,
byran
Old Dec 15, 2010 | 08:54 AM
b_ron007's Avatar
actually i bought 3 years ago.
Old Dec 15, 2010 | 10:05 AM
ettienne's Avatar
My Haynes manual shows 3 mounting bolts on the starter motor. The nut holds the grounding wire and the 3 bolts are on the same side - I don't know if that helps you any.
will97
Sep 7, 2018 09:50 AM
b_ron007
9
Dec 21, 2010 04:44 PM
jimi55lp
Oct 1, 2009 02:56 PM
may1023
Apr 11, 2008 06:07 AM
TiGaTacTics
Oct 11, 2007 09:59 PM
