2001 T&C Limited Electrical Problem?
Old Dec 7, 2005 | 11:17 PM
joconnor's Avatar
Default 2001 T&C Limited Electrical Problem?
Hello everyone, I was hope that someone may have run into the problem we are having with our 2001 T&C Limited.
We bought this car last spring and about a month later we had problems starting it(battery didn't have enough juice to turn it over).
I checked the charging system and it's putting out 14.2V.
I had a battery shop load test the battery and they said it's fine.
I ended up replacing the battery, thinking it may be a bad cell or something and all was fine for about a month.
I then figured I would put a volt meter between the + battery terminal and lead to see what's discharging the battery.
With a volt meter in-line, I then began to remove fuses and relays from the main box. I PULLED EVERY FUSE AND RELAY, and this thing is still drawing current with the key turned off.
Does anyone have any suggestions on how to diagnose this problem?
F150
Nov 27, 2012 04:30 AM
mailmule
Dec 15, 2006 03:33 PM
mailmule
Dec 7, 2006 07:04 PM
joedangerus
Jul 14, 2005 11:35 PM
joedangerus
Jul 12, 2005 02:02 PM
