2001 Voyager 2.5 crd draining battery
Old May 8, 2010 | 03:33 PM
maz2010's Avatar
Default 2001 Voyager 2.5 crd draining battery
hello all,
Would anyone know what causes rapid battery loss (overnight) on this car. I have narrowed down the problem to the 14amp fuse for the radio and remote central locking system. I disconnected the radio completely but the problem persists. Only when I take this fuse off does battery loss cease. Any ideas.
Old May 10, 2010 | 05:09 AM
glowplug's Avatar
Check that one of the internal lights is not staying on, otherwise sounds like you may have a faulty RKE modules. Download the manual for your car and follw the wiring associated with that circuit to see if anything else tails off it. You can find a manual here
http://oskin.ru/pub/chrysler-dodge/manuals/
Old May 10, 2010 | 02:29 PM
Merlin's Avatar
is this the IOD fuse? could well be the battery in the siren that is U/S and is draining the main battery.
Old May 10, 2010 | 04:08 PM
maz2010's Avatar
It is the IOD fuse. merlin - please say more about the siren battery being the cause of this. Where would it be and how could I rectify?
Old May 10, 2010 | 04:11 PM
maz2010's Avatar
Glowplug - I have taken of all the internal light bulbs as they tend to stay on. Sadly this does not cure the problem.
Old May 10, 2010 | 05:21 PM
Merlin's Avatar
All the light bulbs will stay on if the dimmer switch is turn all the way up. The siren in under the L/H/F headlamp, plug up under the wheel arch. Unplug it and see if the drain drops.
Old May 11, 2010 | 05:41 AM
maz2010's Avatar
Hi, I have just disconnected the siren and the drain continues. The other thing, when I put the IOD fuse, the powere mirror motor seems to start automatically even though the engine is turned off completely. Any other ideas?
Old May 11, 2010 | 05:51 AM
glowplug's Avatar
You are looking for a silver bullet. I doubt anyone can tell you exactly what the problem is without diagnosis. I suggested earlier that you download te workshop manual and trace the circuit. If you don't have this knowledge/experience then you should consider an auto electrician.
Old May 13, 2010 | 08:34 PM
71grande's Avatar
On my '01 T&C, I had a battery drain problem. This confused me until one day I went out to the vehicle and the right side power door motor was running all by itself. I disconnected the door motor, and no more battery drain. I haven't gotten around to replacing the motor or doing any other diagnosis.
ayala
Aug 6, 2021 03:35 PM
hankdog101
Apr 28, 2013 07:07 PM
Kavvy
Dec 5, 2012 06:33 AM
maz2010
May 6, 2010 03:53 AM
appalachian
Jun 21, 2009 09:14 PM
