2001 voyager cruise control install problem
Old Feb 19, 2012 | 11:20 AM
freedomghost74's Avatar
Default 2001 voyager cruise control install problem
i installed OEM cruise on my 2001 voyager and all the wiring was already there!!! servo was all installed and also hooked up vacum lines. brake switch has all 6 wires coming out and all 6 pins. wiring harness by motor was already there. i also put the switches in steering wheel and clock spring and wheel were also pre-wired. it all hooked up fine cruise light comes on when i turn on the key now. well it will not work is there some kinda cruise computer that is to be installed down by the brake switch ???? or am i just missing something????
Old Feb 19, 2012 | 04:41 PM
TNtech's Avatar
Go to your local dealer and ask the parts dept to see if there are any updated instructions for that kit. I have quite a few manuals from different installs where I had to make notes at wire connections because they were wrong. Most of them being add-on cruise control...lol.
The answer is no, the PCM does it all. Check your vacuum again first.
Old Feb 20, 2012 | 06:03 AM
Default thanks
i will try that! and thanks for your info ill let u know what i figure out
msd26129
Apr 5, 2014 08:26 AM
carsoftampabay
Cirrus & Breeze
Oct 26, 2012 11:31 PM
AdamsLxi
Aug 15, 2010 04:37 AM
kobbie
Oct 9, 2008 10:10 AM
atlantaestreet
May 10, 2008 12:36 AM
