2002 2.5CRD Voyager citting out whilst idling
Hi guys. Had the car for nearly two years now and tried at random points to fix this problem but still to no avail.
The car has its days when it wont do it as much, it will just bounce off the bottom of the revs and jump up. Recently though its every time the car idles and i dip the clutch, its gettng embarassing at lights and junctions as well as dangerous.
Anybody else experienced this at all? Would love to hear some ideas for fixes.
Sorry just noticed the tittle, *cutting out
Cheers guys
Cheers guys
any fault codes? search up "key dance" on here
when you say it cuts out with the clutch dipped, do you mean only with the clutch pedal down or if it's stationary and in neutral with the clutch up will it cut out?
Regards
Richard
Regards
Richard
EGR valve has been changed, so has the fuel filter and housing. The crank sensor has been sugested but its not been changed as yet.
Looks like cam/crank sensor maybe next to try ?
Rich
Sorry for being a little slow but whereabouts would the harness's be within the engine?
