2002 Chrysler Town Country - Not Starting
Old Oct 2, 2013 | 08:43 AM
  #21
vg1972's Avatar
Thanks for the reply Leedsman. Now my friend wants me to see if I cans solve another couple issues with the van. One is an erratic idle, sometimes even staling out at a stoplight. I am thinking maybe the egr valve since I noticed the solenoid chattering constantly while idling and it is hot to the touch. Even if the engine is not warmed up yet. Sound like a good place to start?
Another problem is the speedo and tach do not function at all. Wish I had more info on that but they just sit there. Any ideas?
Old Oct 2, 2013 | 03:00 PM
  #22
Raptor 07's Avatar
All PCI communications data bus wiring is white with a violet tracer. Grounding that wire killed the bus. Data bus wiring runs all over the van including to your sliding doors, the tailgate, PCM, BCM, TCM, HVAC panel, ACM, instrument cluster and uh, your radio. Damage that wire anywhere in the system and odd things can happen including no starts. You probably couldn't start because the PCM couldn't communicate on the dead bus. Like Leedsman said, "That's microprocessors for you..."
The dead tach and speedo could be data bus related. You may see a code if you can get a scanner that can read communications codes. You could try a self test - hold cluster ***** in then turn key to on. It may give you a code on the odometer display and if the gauges cycle, tell you the cluster is ok.
eljefe25
Oct 31, 2013 01:46 AM
Quickshot23
Oct 18, 2011 04:20 PM
Daryl Baines
Mar 3, 2011 05:21 PM
safetyman
Sep 16, 2008 01:46 PM
follett108
Nov 24, 2007 09:24 AM
