2002 T&C Air cond from driver's side vents is not cold
Old May 10, 2007 | 05:19 PM
rrhea's Avatar
Default 2002 T&C Air cond from driver's side vents is not cold
When using theair conditioning, the uppervents on the driver's side blow slightly warm air while the passenger side vents blowvery cold. I've got both sliders on the controller all the way to the left.
Sometimes after about 20-30 minutes of driving, the driver's side vents will all of a sudden start blowing cold air. (but still not quite as cold as the passenger side)
Also, if I slide the driver's side temperature slider on theAC controller back and forth from cold to warm to cold, sometimes after 6 or 7 tries, the left side vents turn cold.
Any educated guess as to whether it may be a either a flap or the controller itself?
Old May 10, 2007 | 06:08 PM
Default RE: 2002 T&C Air cond from driver's side vents is not cold
U have a leaking condensor which is the big grill looking thing in front of the engine. The freeon is low so it will only coll hafy of the air comming is the driver side air is the furthest away so it is warmer. look at the front of the condensor on the passanger side lower corner u will see wet spot.
Old Jul 14, 2008 | 06:43 AM
rcgamble's Avatar
I have the same issue with my a/c on my town and country....the passenger side blows warmerer than the driver side. I have put in freon with leak sealer and everything worked fine fora couple of days then the freon ran out and we're back to blowing warm air. I had thought the leak was in the dashboard and hesitate to pull the dashboard out given the labor involved. I'll check the condensor in the engine. I also hear in the rear right vent a hissing noise and am curious if there is possibility of a leak there or if this is normal?
Thx. Bob
Old Jul 14, 2008 | 08:51 AM
rrhea's Avatar
I found out through my local mechanic that Chrysler had extended the warranty for the AC in this vehicle due to known issues. I took it to my dealer and they repared it at no cost to me.
Old Aug 3, 2016 | 05:16 PM
Mario Lapi's Avatar
I have this problem but on driver side floor corner there's nothing wet could it be leaking someplace else
Old Apr 22, 2022 | 05:30 PM
Jam3466's Avatar
So what was the problem?
Kav
Other
Aug 7, 2015 07:13 PM
airplane fixer
Aug 13, 2011 08:05 PM
Stingray
Jul 24, 2011 07:51 PM
BARCLAY
May 19, 2010 04:57 PM
RobNordic
Sep 14, 2009 07:40 PM
