2002 T&C Transmission Problem
Old Apr 23, 2013 | 02:28 PM
thomascathybell's Avatar
Default 2002 T&C Transmission Problem
My vehicle is a 2002 Chrysler Town and Country with a 3.3L engine. The vehicle has approximately 130,000 miles on it. I don't know if the transmission oil and filter have ever been changed. Yesterday, with no previous problems, a loud whine started while I was driving at about 45 miles per hour. At first I thought it was an ambulance siren. One mile later, the transmission stopped working as if it were in neutral rather that in drive. I stopped the car, turned it off and restarted. It drove for about a mile and then the whine came back and it stopped working again. There are no permanent codes and the check engine light is off. I hooked a scanner up and there are several pending codes- P0700, P0731, P0733, P0734, P0841 and P0846. The transmission fluid is at the proper level. The transmission does NOT enter the limp mode. What should I look for?
Old Apr 23, 2013 | 05:18 PM
The whine is relevant to the speed of the transmission? the codes are gear ratio errors and pressure switch codes Im gonna say U have a bad front pump which means the trans would need to come out
Old Apr 23, 2013 | 08:28 PM
Yes, the whine changes with the speed of the engine. The whine exists when stopped in drive or stopped and in neutral.
Old Apr 24, 2013 | 06:44 PM
This is a follow-up for the benefit of others to see. I replaced the filter and fluid this evening. Afterwards I drove for about 10 miles and the problem seems to be completely solved.
Old Apr 25, 2013 | 02:59 AM
joker2cv's Avatar
Your trans filter could be clogged. Try to change oil and filter first of all.
Old Apr 25, 2013 | 08:34 PM
humm this is deff gonna sound like an *** but I cant help it. joker did u by chance read what was posted above your??? Really.
Old Apr 26, 2013 | 07:08 AM
joker2cv's Avatar
Sorry mate...
Old Apr 26, 2013 | 09:38 AM
its all good lol I have boys at home so I myself hate having to repeat myself like 10 times for the same answer.
Old Sep 30, 2013 | 04:32 AM
Steve66's Avatar
Thank you. I was experiencing very similar issues on my UK 2005 2.8 CRD. All of the gear ratio codes plus 0845 and 0846. It would drive fine for a few minutes then gear change problems would start, going in to neutral, engine management light coming on plus an intermittent whine/rattle. I changed solenoid assembly and input/output sensors based on the info I got from the internet/forums etc. Same issues. Changed the filter (and oil) and so far so good. If you look at the Chrysler service A schedule the transmission filter/oil are a none serviceable part! On the B schedule it needs changing approx every 90000k depending on which Chrysler info you read! I bet most cars are probably serviced on schedule A but reading on what classifies servicing it on B I think most should probably be on B.
jminter
Jul 3, 2019 10:14 AM
jan.murawski
May 4, 2014 06:52 AM
T-J
Jul 26, 2013 07:31 PM
hunterbaye
Jun 17, 2011 01:44 PM
oea
Jan 29, 2011 07:14 PM
