2002 voyager wont start
Old Apr 29, 2010 | 01:09 PM
sledfreak700's Avatar
Default 2002 voyager wont start
I have a 2002 voyager with a 2.4 and the other day it broke down while driving,i towed it home and checked the codes and i had a few,mostly emmision codes but it did flash 0340 and 0403.well i took it apart and the timing belt blew,so i changed that and the tensioner it was toast as well.put it all back together and it still will not turn over.i thought the computer had to be reset so i disconected the battery and still nothing.Now the only code that comes up is the one about the battery being disconnected.My question is if the camshaft sensor did its job when the belt blew "is it bad".I know everything is lined up correctly,i just didnt want to tear it all apart to find out the sensor is bad.There is no way of knowing if it's bad or not?...Please help if you can.Sorry about the long read,,,Thanks
Old Apr 29, 2010 | 07:17 PM
I just wanted to clairify it wont even turn over,i just replaced the cam sensor and that did not help either.Any help would be greatly appreciated...thanks
Old Apr 29, 2010 | 08:58 PM
the starter wont turn over the engine?
Old Apr 29, 2010 | 09:27 PM
No the starter does turn over.It hits but just stops,it just doesnt crank over.I was watching the cams srockets and it just hits for a second and then quits
Old Apr 30, 2010 | 06:37 AM
possible bent valves or head damage timing is wrong
Old Apr 30, 2010 | 10:39 PM
The timing was off.thanks for the help
55mopar
Jan 26, 2013 08:30 PM
ekhealy
May 23, 2011 10:47 PM
aaronsedge
Feb 5, 2011 11:14 AM
rjdavis61
Sep 26, 2010 06:53 PM
LTEDT
12
May 8, 2007 01:05 AM
