2003 T&C front heater blower stays on low, won't go up to high
Old Dec 15, 2008 | 12:14 AM
loral's Avatar
Default 2003 T&C front heater blower stays on low, won't go up to high
Tonight, it was 10 degrees when I came out to the car and when I turned on the heat to high and set the temps to 85, the heat didn't really blow well. When I started oving, the back heater went to high immediately and started blowing and warming the car. The front heater stayed on low, although it was turned up to high. I changed it from defrost to vents and still blew warm air on low.
I am trying to avoind the dealership if this is a simple fix. Any suggestions as to what part to buy.
Is it a simple fix?
Lora
Old Dec 15, 2008 | 06:37 AM
Default RE: 2003 T&C front heater blower stays on low, won't go up to high
blower motor resistor.
Old Dec 15, 2008 | 07:02 AM
loral's Avatar
Is this an easy fix that me, a female with no car knowledge, can do?
Old Dec 15, 2008 | 08:54 PM
2 screws behind the glove box
Old Dec 15, 2008 | 10:09 PM
Rick99's Avatar
ORIGINAL: loral
We all have to start somewhere. Does you van have automatic temperature control (where you set the temperature you want digitally) or is it manual? The job is just as easy either way, but it affects whether you need a blower resistor or a "blower speed control module".
As far as the job goes, just empty your glove box, squeeze the sides together and let it hang all the way down (it will be upside down and you'll have access behind it. The thing you see with the electrical connectors and two screws holding it in is the resistor/speed control module. Unplug the connectors (you may have to slide a red slide on them over to the side then pinch the tab to release them, if they're that type), remove the screws and pull the old resistor/speed control out, put the new one in, plug in the connectors and you're good to go.
If it is a resistor, you should be able to get it at any parts place about $20), if it is the blower speed control module, you'll have to get it at the dealer parts desk (about $80).
Old Dec 16, 2008 | 12:39 PM
loral's Avatar
In my car, I set the temp and it's digital so I assume that would be automatic.
I called on place and they quoted 80 for the part. Is that correct?
Old Dec 16, 2008 | 04:36 PM
Rick99's Avatar
ORIGINAL: loral
You mean you called the dealer right? Only the dealer will have the part. Yes $80 sounds about right. It does sound like you have automatic temperature control you can always give the dealer the last 8 digits of your VIN and they can make sure you're getting the right part.
BTW I've had two of these things go on my wife's van in the last3 years each time the part had been redesigned.
tmjones
May 27, 2015 10:00 PM
needn help
Mar 7, 2015 02:12 AM
NoLove
Jul 5, 2010 08:26 AM
dm6174
Nov 11, 2009 05:39 PM
kunkeljm
May 20, 2008 02:29 PM
