2004 Chrysler Grand Voyager 2.8 CRD Alarm battery fault
Old Aug 9, 2009 | 04:17 AM
Ian's Avatar
Ian
Default 2004 Chrysler Grand Voyager 2.8 CRD Alarm battery fault
Hi i have a 2004 Chrysler Grand Voyager 2.8 CRD yesterday the battery went flat so i jump started it today the alarm went off for no reason that i can tell so i put a new battery on and the alarm wont reset the doors won't lock/unlock and it won't start the alarm goes off all the time when the battery is connected any ideas Thanks.
Old Aug 9, 2009 | 04:33 AM
Merlin's Avatar
Hi
Have you checked the fuses? The alarm should stop as soon as you turn on the ignition if not by the fobs. Does the locks work on the switches inside on the doors? Don't try to start if straight off just turn on the ignition and you should see the gauges do a sweep and the indicators flash.
Old Aug 9, 2009 | 04:51 AM
Ian's Avatar
Ian
[quote=Merlin;29690]Hi
Have you checked the fuses? The alarm should stop as soon as you turn on the ignition if not by the fobs. Does the locks work on the switches inside on the doors? Don't try to start if straight off just turn on the ignition and you should see the gauges do a sweep and the indicators flash.[/quo
When i tryed it yesterday i turned the ignition on and the alarm keeped going the indicators did not flash and dont when the alarm is going
Old Aug 9, 2009 | 05:28 AM
Ian's Avatar
Ian
Smile
Originally Posted by Merlin
Hi
Thanks mate you were spot on fuse had gone (brake lights) dont know what that had to do with the alarm but its all good now
travelmad
Oct 29, 2013 07:52 AM
voyager3000
Jul 18, 2012 02:11 PM
Jimbo1
Feb 24, 2012 05:16 PM
robtheplumb
Sep 29, 2011 03:13 PM
stewartsoftware
Apr 17, 2011 03:22 PM
