2004 Grand Voyager battery drain
Old Aug 24, 2009 | 02:55 PM
Ian's Avatar
Ian
Default 2004 Grand Voyager battery drain
2004 Grand Voyager battery drain. Battery goes flat after 5 days dvd player stays lit up even when the ignition is off and the key removed don't know if this is the problem but i am sure it wont be helping any body got any ideas
Old Aug 24, 2009 | 05:14 PM
Merlin's Avatar
Check it's not a faulty ignition switch and you are removing the key in the auxiliary position?
Old Aug 25, 2009 | 01:47 AM
Ian's Avatar
Ian
Switch seems to be fine key only comes out in the correct position
Old Aug 25, 2009 | 08:05 AM
Master Chief's Avatar
I assume that the DVD player is fused, hopefully, so I would suggest to remove it, or just disconnect the DVD player to see if that's the one cause the trouble.
Old Aug 25, 2009 | 04:39 PM
Ian's Avatar
Ian
The fuse had gone for the cd so i replaced it made no differance how do i get the surrond off i can only find 2 screws at the top but it dose not want to come off? so i can disconnect the dvd
Old Aug 25, 2009 | 09:42 PM
the dvd gets power from the radio I bet the radio itself is causing the drain seen it a few times.
Old Aug 26, 2009 | 04:36 AM
Ian's Avatar
Ian
OK i have removed the radio and dvd and rechecked the fuses to find (fuel heater ) fuse blown replaced and started the car fuse gone again could this be linked someway to the dvd unit to light it up or am i just getting more problems?
Old Aug 26, 2009 | 09:01 AM
Merlin's Avatar
Hi
unplug the fuel heater and retry see if it blows again but should be unrelated, filter housing can short out. Is your DVD player a factory unit or a mopar unit or after market? single or 6 disc changer? (Mopar unit will say mopar on the remote) You should also have an RB3 sat nav radio yes? I agree with Chrysler Tech and it will most likely be the radio at fault.
Old Aug 26, 2009 | 03:04 PM
Ian's Avatar
Ian
Hi
Where do i find the fuel heater?. Yes it dose hsve a sat nav radio and a mopar dvd
Old Aug 26, 2009 | 05:19 PM
Merlin's Avatar
Hi
On the fuel lift pump by the tank. I am sure this is the same fuse that is the voltage sense for the PCM so will also affect the charging. You can check this because if it is you will see the headlamp flicker when at idle and lights on.
