2004 Grand Voyager battery drain
Old Aug 30, 2009 | 08:54 AM
Ian's Avatar
Ian
I unpluged the fuel heater and it still blows fuses there are 4 wires to the fuel heater do you know where they go the red one gose to the fues box has any body got any idea where the others go as i cant find a wireing diagram anywhere i reconnected the radio and there dose not seem to be a drain on the battery the dvd is still unpluged if i plug that bacvk in it stayes on all the time
Old Aug 30, 2009 | 02:36 PM
Merlin's Avatar
Hi
The other wire are for the lift pump. If it still blows then look around the bracket that covers the ECM in front of the battery seen then rub and short out on it. From memory that wire also goes to the ECM and the heater on the engine breather.
Old Sep 1, 2009 | 02:39 PM
Merlin's Avatar
Hi
Funny I had a 2005 in with the same faults today. Fuel heater fuse blown was due to the heater on the engine breather sorted. Battery drain I did think was radio/dvd turned out to be the amp.
Old Sep 2, 2009 | 08:21 AM
Ian's Avatar
Ian
Originally Posted by Merlin
Hi
Where do i find the engin breather. As for the battery drain i put everything back in except the dvd and there is no drain on the battery so i think mine is the dvd need to get one from somewear
Old Sep 2, 2009 | 01:43 PM
  #15
Merlin's Avatar
Hi
air filter follow it to the engine you will see the engine breather goes into that pipe and there is a plug with 2 wires in it. My one was 0.4 ohms and blowing the fuse, tested a good one and it was 9.3 ohms.
voyager78
Jul 10, 2010 08:03 AM
Ian
Aug 9, 2009 05:28 AM
Dave Rogers
Mar 1, 2009 08:32 AM
Chan2169
Dec 10, 2008 03:16 PM
quattj
Feb 2, 2007 10:30 AM
