2005 Chrysler Voyager 2.8 CRD LX P1130/start problems
Old Nov 19, 2013 | 04:33 PM
  #21
voyageraholic's Avatar
Default Voyager needs key turned many x's b4 starts???
Have a 00 Chrysler Voyager 150K miles. About a week ago, I noticed I go to turn on the van, turn the key, sounds just like a dead battery, one turn of the engine or 2, maybe less, then nothing, try again, engine turns over again or not at all, 3rd time, sometimes turns right over or nothing, etc. but will always (so far) eventually turn over & run like nothing happened. Drives normal, the lights, controls are always lit up throughout the ordeal. Have no idea whats going on?? Battery was replaced 6 months ago.
Sometimes it pops over on the 1st key turn, but it seems to be more & more consistently taking a couple times to start. Any thoughts?? bad ground?? I did have issues with the key not wanting to turn a year ago, nothing lately, could it be a ignition switch?? Sensor?? Any help, its getting cold in MN, dont want to be left out in it!!
Old Nov 20, 2013 | 10:05 AM
  #22
tfb's Avatar
tfb
makes it a bit easier to read if you start a new thread.
From the symptoms I would suggest looking at the earthing straps on the engine and to the battery/chassis
Regards
Richard
Old Nov 22, 2013 | 01:40 PM
  #23
vrc8883's Avatar
Can't argue with that, although I guess I would remove and clean electrically connecting parts. I would check and clean both posts and clamps on the battery too.
Mike
Old Jul 27, 2015 | 06:19 AM
  #24
John Norrish's Avatar
Did anyone get to the bottom of this as my 2003 2.5 DRC with 84k miles has started this, always starts from cold, leave for 1/2 hour when hot and no chance have had the Cam Shaft sensor replaced but have been told on mu other post that the Cam and Crank sensors work as one, so am waiting for delivery, I do wonder if I have a real live Gremlin?? When starting after an Hour it goes first time drives great plenty of power
Old Jul 27, 2015 | 02:17 PM
  #25
Lets hope you have no issue with wiring to the sensors. Mind check sensor wiring connector is good.
Old Jul 28, 2015 | 05:11 PM
  #26
tfb's Avatar
tfb
find someone with an oscilloscope. Monitor the crank and cam signals at the sensors and ECU while cranking. It's a lot cheaper to diagnose than keep buying parts
Regards
Richard
Old Aug 3, 2015 | 03:21 PM
  #27
drisaacs's Avatar
Default Common rail pressure relief valve fault.
Hi all, Thought i would share my recent experience with you.
I have been having problems starting my Grand Voyager 2.8CRD for some time and decided to test my pressure relief valve a while ago. Please see video. Its a really simple test, you just need some clear tube, a small bottle and something to block off the pipe removed from the valve.
As you can see from the video the valve was opening on cranking and engine idle once started. This it shouldn't do.
I eventually got around to changing the valve this weekend as it had got a lot worse and even embarrassing trying to start it. It now starts 1st time very well and I do not have to use the throttle while cranking anymore. Also I have noticed that i am not getting lots of smoke on acceleration as I did before.
Old Aug 5, 2015 | 02:52 PM
  #28
Good answer to starting there from drisaacs and an easy test. Lack of pressure in the fuel rail that has this valve, injectors leaking just off the rail and the rail pressure sensor culminate on this fault. Its a wonder the engine wasn't cutting out under load or was this the next stage. Also this loss of smoke under acceleration is interesting.
Old Jul 3, 2021 | 03:57 AM
  #29
FunkyJunky's Avatar
This is really useful, sounds just like the problem I am having. Do you know what the torque setting is required for the pressure relieve valve please
Many thanks
Andy
kkc
17
Aug 29, 2015 12:32 PM
lianandwayne
Mar 30, 2014 10:24 AM
Jacob25crd
59
Oct 18, 2012 03:30 AM
steveo
Oct 28, 2011 06:20 PM
davoy
Feb 17, 2011 03:20 AM
