2005 T&C battery light on
Old Oct 1, 2017 | 05:12 AM
ronAVL's Avatar
Default 2005 T&C battery light on
I just purchased a 2005 T&C touring with the 3.8 engine. 68000 miles. It runs and drives great.
The battery light has been on. I replaced the battery and alternator but the battery light and check engine light are both still on.
I am getting the following codes.
P0645 - A/C clutch relay (the relay is good)
P0443 - Evap purge control system
P0499 - Evap system vent valve
P0622 - Generator field not switching
P0403 - EGR valve
My next step will be to check and clean all ground connections, and look for loose or frayed wiring.
Could I have a bad ECM? and if so, how do I diagnose that?
Any help would be appreciated.
Old Oct 1, 2017 | 08:46 AM
REBEL59's Avatar
Have you checked fuses and connections(grounds)? Not often to hear of replaced alternators not working and keeping the battery light on. Hope it was a reman alternator as the 3.8 uses a clutched pulley drive and can go bad not "hooking up" to the alternator shaft to allow it to charge. Have had that happen to me on 2 of my past vans.
As for the other codes... sounds like you have other concerns to be checking out, AFTER getting the charging system working.
BTW: Have you confirmed voltage output(charge) with a voltmeter?
kf1331
Feb 24, 2016 01:16 PM
bgeise
Sep 12, 2014 10:38 AM
qbasicer
Sep 25, 2012 02:58 PM
Gasman
Feb 14, 2011 04:17 PM
ladyas
Dec 13, 2009 06:09 PM
