2005 Town and Country
I have a 2005 T and C and the drivers' side sliding door won't unlock.
It is not the actuator as I have removed it. I pull on the levers inside the door panel and nothing unlocks.
The problem is in the latch and it must be stuck. I have shot wd-40 in.
How do I open the door? Is there a way to disconnect the latch from inside the door?
Thank you!!
Chuck
Thank you!!
Chuck
The bolts that hold the door in place are only access able from the door being open. You need to get right to the latch itself and pull on the leavers if you have child lock on that will make it worse .
Glnla
Jan 19, 2018 04:12 PM
dgorgone
Oct 20, 2012 06:41 PM
Raybart
Dec 20, 2008 10:47 AM
