2006 Chrysler Grand Voyager Trans Cooler Lines
Old Apr 4, 2022 | 04:56 AM
Chargenut's Avatar
Unhappy 2006 Chrysler Grand Voyager Trans Cooler Lines
Hi all,
Got a Transmission oil leak on the oil cooler lines on our 2006 Chrysler Grand Voyager 2.8 CRD.
Tried to source some new ones via the Dealership and they are not stocking them anymore.
Anyone got any ideas where I might source a pair of pipes? Or any ideas on how to repair the ones that we currently have? (looks like the metal parts of the pipes have rusted through).
I was wondering if the cooler pipes from a 2008 GV (which I can source) might lend themselves?
Cheers,
Terry.
Old Apr 5, 2022 | 05:06 AM
user 7698720832's Avatar
Don't know where you're based but any hydraulic pipe supplier should be able to make one up on site.
Old Apr 6, 2022 | 04:35 AM
Chargenut's Avatar
Hi Richard, thanks for your reply. Yep that's a good idea. I'm based in the UK and am planning on getting the pipes off the car and taking them to Pirtek to see what they can make up. I'll post on here with the results of that approach.
Thanks again,
Terry.
Old Apr 6, 2025 | 12:14 PM
peterEH's Avatar
Hi Terry,
How did you get on please? Same issue.....
I have a 2006 CGV 2.8CRD. My lines to the transmission oil cooler are leaking at the clamp that clamps the lines together a few inches back from the cooler.
I can see that getting to the bottom of the lines will be a challenge - I can remove battery holder and coolant bottle holders, but there's still cooling hoses and wiring harnesses making access at the transmission hairy.
Thinking maybe easier to effect a repair (cutting out bad section and using high pressure hose) instead?
Any advice gratefully received!
Thanks,
Peter
UPDATE- in the end I sourced replacement lines from a breaker but they leaked even worse than my originals so I had new lines made up.
keithm
Nov 24, 2020 05:06 AM
AlanC
Jul 10, 2015 06:51 AM
chuckle1
Aug 11, 2012 05:01 AM
joker2cv
Apr 19, 2012 02:55 AM
Ian
Aug 24, 2009 05:20 PM
