2009 Dodge Grand Caravan SE Parasitic Battery Loss
Old Dec 1, 2019 | 03:57 PM
TheCure's Avatar
Default 2009 Dodge Grand Caravan SE Parasitic Battery Loss
Hello all, this is my first post. I am in need of help regarding an electrical issue plaguing my 2009 grand caravan.
My newish battery drains nightly.
The problem has been traced to the IOD 60a fuse. With this pulled, the draw is around 30ma - within specs.
With fuse installed, the ammeter shows 1.45A drawn for about 10 seconds, then 0.5A for about 25 seconds.
I know this fuse supports all feeds outside the ignition switch/// alarm, interior lights, radio, etc. There are countless circuits attached to this one fuse which are not in turn fused, which makes for a very difficult diagnosis.
I was hoping someone might have seen this same phenomenon, and can point me to the culprit(s).
Thank you in advance!
Old Dec 3, 2019 | 12:22 PM
May not be relevant on your 2009 but on my 2007 I eventually traced the drain to the audio amp which is not on the IOD fuse. The amp on my model was mounted inside the rear panel where it can collect condensation. The plug connector had oxidised and was shorting out.
See my post at the bottom of this page: https://www.chryslerforum.com/forum/...d-28405/page3/
Old Dec 11, 2019 | 10:37 AM
Scotsman4th's Avatar
Mines was because there had been an after market stereo fitted at some point. A switched live had been altered to give a permanent live.
Old Apr 3, 2020 | 12:21 PM
Lufla's Avatar
Banned
Default Fusível de seta
Amigos tô com um problema que está me tirando o sono , minha G.C é ano 97 e apareceu um defeito : toda vez que passo a alavanca de marcha na posição P ou N queima o fusível de seta < ou seja não tenho seta e isso só acontece nessas posições se estiver no D, 3, L ou N eu consigo colocar o fusível mais no P ou N é colocar e queima na hora. Alguém pode me ajudar?
Lexicon
May 8, 2023 07:51 PM
paulstevens
Sep 2, 2016 09:47 AM
Leedsman
16
Aug 29, 2014 10:09 AM
docdrs
Sep 17, 2012 01:52 PM
