2009 T&C with power 3rd row seat problem
Old Aug 15, 2011 | 03:34 PM
northfork's Avatar
Default 2009 T&C with power 3rd row seat problem
The double seat on the drivers side works (push the “stow” or “normal” and it returns to that position) but the single seat on passenger side dose not respond at all. Had the motor checked (inside back) and it works fine. Did not check the motor in the seat (hard to take out). Is there a breaker or in-line fuse for this seat only? Could the motor in the seat be bad and stop the power getting to the inside back motor?
Thanks in advance.
Old Aug 16, 2011 | 08:47 AM
ChryslerCares's Avatar
northfork:
Unfortunately, given the many variables involved, I'm unable to diagnose your vehicle's problem via email however I was able to locate a TSB that may apply to your concern.
I have listed info below for your review. I would suggest having your dealer diagnose and perform the TSB if it applies to your concern.
TSB #08-001-09
SYMPTOM/CONDITION:
Customers may experience an intermittent or partial unlatch of the 60 percent third row seat inboard latch while attempting to stow the seat. Customers may experience the Third Row Power Seat back located in the folded position, on the seat cushion, preventing the seat from being used. A second attempt to store the seat may or may not be successful. A software design change has been made to eliminate these intermittent unlatch conditions.
SUBJECT:
Flash: Third Row Power Folding Seat Module
This bulletin involves flashing the Third Row Power Folding Seat Module (FSM) with new software.
Hope this info may point you in the right direction but I would suggest having a dealer diagnose to be sure.
Old Aug 17, 2011 | 12:01 PM
northfork's Avatar
Thanks ChryslerCares for the info. I did find one more problem the (Part #68028320AA SEAT BACK RECLINER) is locked up and will not fold. Can you recommend a good parts place online?
Old Aug 17, 2011 | 02:47 PM
northfork:
Your very welcome.
Parts and accessories can be ordered on-line at the Mopar eStore. The Mopar eStore can be found on-line at Mopar Parts - The Official Mopar Parts eStore offered by Chrysler
If you wish to speak with a representative, you can call the eStore Hotline at 1-888-349-2298.
There are several retailers that may be able to help. Here are a few:
Mo-Par City
Used parts, some rust-free sheet metal, restoration parts
Website: http://www.moparcity.com/
Phone: (800) 426-HEMI
Brad's NOS Parts
Restoration parts generally for 1955 through 1993 MYs
Website: http://www.bradsnosparts.com/
Phone: (803) 755-0066
Lambert Auto Sales
Source for parts for Chrysler (1960-present), Jeep (1940-present), and AMC/Renault vehicles.
Website: http://www.lambertauto.net
Phone: (800) 726-2104 (Parts)
Surplus City
http://www.surplusjeep.com
Phone: (800) 353-3772
You may also order parts and accessories through your local dealer.
Old Apr 1, 2023 | 05:28 AM
JannickHalben's Avatar
Here is a video showing how to repair the Frozen mini-gear on each seat backs corners. This gear block the henge movements and therefore the corner (1or2) will not move up the rear seat back from unfolded position.
Note if you have faults of functions DO NOT HELP THE SEAT MOVING but fix the problem. If you help the very powerfull motors they can flip the stearingbrods around and even twist the henges & fixtures until they looks like a spring g break the rods & guides.
Prevent failures - grease spray all links & bushings & springs &bcables & guide with a little wd40 every 2 years (same apply to the adjustable food-brakes rods and links & screw-shaft).
Gumby
Apr 1, 2023 05:22 AM
ww4cash
Dec 10, 2022 09:44 AM
maintenance
Jan 19, 2014 10:28 PM
Javivi
Jan 17, 2012 05:00 AM
STilt66
Nov 18, 2011 09:11 AM
