2010 chrysler town and country cooling fan
Old Jun 26, 2019 | 10:21 AM
Charlie Marie's Avatar
Default 2010 chrysler town and country cooling fan
I have a 2010 chrysler town and country 3.8 the cooling fan was replaced and seems to run alot more often Im wondering if anyone knows witch way air is suppose to go mine is blowing out the front from engine compartment I have always seen on other cars air comes from outside into engine compartment Im wondering if this unit was wired backwards or not.Thanks Ken
Old Jun 26, 2019 | 10:29 AM
Have you got yours set to recirculate the air inside of the car or is it set to draw air in from outside?
Old Jun 26, 2019 | 10:31 AM
Sorry This is the cooling fan for radiator
Old Jun 26, 2019 | 11:57 AM
I should have realised
Old Jun 26, 2019 | 02:59 PM
REBEL59's Avatar
Did someone wire in a new connector to the fan? Sure sounds like the polarity was reversed on the 2 wire connector IF that was the case. You are correct that it should draw air from outside into the engine bay thru the grill.
Old Jun 26, 2019 | 06:06 PM
I called 2 Chrysler garages got 2 different answers of witch way flow should be and no the pug was never cut the fan was wired wrong I just switched direction and seems to be working fine now but thanks for your help just in case anyone else installs a new fan it it suppose to take from outside into engine compartment just like I thought but when I called first Chrysler garage and they told me outward so it had me baffled for a while.
Silentdub2
Jul 2, 2018 07:57 AM
orions8
Dec 7, 2016 11:22 PM
cris1966
Aug 26, 2014 09:59 AM
colbertgang
Apr 26, 2009 09:30 PM
dandiesel
Feb 2, 2007 08:24 PM
