2010 Town and Country will cold start start but not warm start
Old Mar 9, 2020 | 07:28 AM
jamin_b's Avatar
Default 2010 Town and Country will cold start start but not warm start
Van cold starts and runs fine, of however you run in a store for 10 minutes and come back to start it, jt will crank and stall. Once engine cools down a little it will start and operate as normal.
things it isnt
1. battery
2. battery connections
3. MAP
4. IAT sensor
5. dirty throttle bottle
6. electrical resistance through coils or injectors om bank 2
Im about to loose my mind over this van
Old Mar 11, 2020 | 04:15 AM
IATinBLACK's Avatar
Sounds VERY much like cam or crank sensor, probably the cam. Warms up, cuts out. It's only needed when starting and is giving wrong information when warm.
You could test it with coldspray or put in ice when warm. Cam sensor is easy to remove, at least in older models.
Crank sensor gives the engine timing so you should have other problems with it..
n9yty
Apr 17, 2020 04:57 PM
J-man
Dec 22, 2014 09:02 PM
lilbit2008
Sep 28, 2008 10:28 AM
paul.siwek
Aug 23, 2007 07:51 PM
cheechster
Feb 7, 2007 07:31 PM
