2011 t&c airconditioner low side port for charging
Old May 25, 2016 | 03:52 PM
shirlock1's Avatar
Default 2011 t&c airconditioner low side port for charging
I am having the dickens of a time finding the low pressure port of the a/c system. I need to top off the r-134 for a trip. Anyone got any idea where to look. I found high side port and found part of the alum tubing for the low side but no port.
Jim
Old May 26, 2016 | 12:20 AM
matgriff's Avatar
The low side port will be near the compressor on the suction line.
On a 2001-2008 voyager it's located right by the compressor, directly between the compressor & the radiator. You need to slide your hand down past the rad hose and it's there. Also you can't really use one of those short charging hoses as it's quite a way down. You need an extension or a proper set of manifold gauges with a charging hose.
Mat
Old May 26, 2016 | 03:57 AM
Mat
The location will probably depend on the engine type. The OP hasn't specified which,although it's Stateside so probably petrol.
Old May 26, 2016 | 05:56 AM
shirlock1's Avatar
Default 2011 Town and Country
My vehicle is a US version. It is 2011 and so it is the 3.6 engine. sits transverse so that a lot of the perhipals are hidden.
Appreciate any help.
Jim
Pistel
Nov 5, 2013 03:19 PM
ww4cash
Jan 4, 2012 08:47 PM
om1tooth
Aug 2, 2009 06:05 PM
goldsmi
Jun 7, 2008 02:28 PM
cwbritt
Aug 17, 2007 11:28 AM
