2012 T&C Overheating
Old Sep 18, 2024 | 02:17 PM
Injected67's Avatar
Default 2012 T&C Overheating
Hello out there! Looking for some guidance as to why my 2012 T&C keeps overheating. I've changed the water pump, thermostat, radiator, radiator fan relay, and purged all air bubbles from the system, yet the temperature gauge still wants to creep past half every time I'm at a stop, or in stop and go traffic. Any ideas?
Old Sep 19, 2024 | 04:44 PM
did you actually test the things you replaced or just threw them in? If there was no actual reason to have them replaced you now will need to deal with bad or cheap parts or workmanship issues as far as install.
need a scanner to see what the actual temp is of the engine when you see this happen and if you wait long enough do the fan turn on and cool down the engine?
Old Sep 23, 2024 | 08:57 AM
OldManInaMiniVan's Avatar
Did You Check the E.C.T. Engine Coolant Temp Sensor?
ricksaldana
Sep 11, 2022 07:52 PM
gefox4
Oct 4, 2021 04:05 PM
TurboDodge
Feb 16, 2020 01:31 PM
curiousv
Jul 29, 2017 09:10 PM
vulcancat
Mar 7, 2015 09:31 PM
