2013 Town & Country Sliding Door issue
Old Aug 14, 2017 | 08:57 PM
blaze276's Avatar
Default 2013 Town & Country Sliding Door issue
On my 2013 the passenger sliding door works fine most of the time,occasionally when it closes, the rear cinch motor will cycle in and out and will continue until you walk back and tap/ knock on the door in the area of the motor. You can watch it pull it in and then release it. The knock or tap is not hard enough to move the door , it is just hard enough to cause a vibration Any thoughts?
Old Aug 15, 2017 | 05:45 AM
REBEL59's Avatar
Lube the door hinges and rollers, when they get "sticky" the door will not close far enough to make good contact with the switches in the door latch for "end of cycle". Also I have noticed that operation of the sliding doors when vehicle is on an angle or uphill grade can make the doors "act" oddly(not want to shut), without some human hand guidance.
Old Aug 15, 2017 | 05:58 PM
Raptor 07's Avatar
"...operation of the sliding doors when vehicle is on an angle or uphill grade..." Yet another Chrysler poor design issue for the list.
Old Aug 15, 2017 | 09:04 PM
REBEL59's Avatar
What list do you refer to? I would still take a MOPAR minivan over all other contenders! But that is my personal opinion.
Old Mar 7, 2024 | 10:40 AM
aharon's Avatar
Default Town Country 2012 right sliding door
Hello, my Town Country 2012 also has the same problem with the right sliding door
Can I cut the cable and also disconnect the Wiring Track Harness ? do you think the windows etc will be ok after disconnecting the Wiring Track Harness
tbird2340
Nov 8, 2014 10:29 AM
Huslayer
Jan 28, 2013 10:14 AM
hoopsnut
Jan 8, 2013 04:17 PM
cchis
Feb 19, 2012 09:15 PM
Raybart
Dec 20, 2008 10:47 AM
