3.3 no run
Old Jun 22, 2012 | 12:15 PM
dlomonaco's Avatar
Angry 3.3 no run
My 2000 Town and Country will not run. It cranks but does not start. No sign of fuel or ignition. Suspecting a camshaft or crankshaft sensor, I atttached an ODBII scanner. It shows nothing, but amazingly the car starts and runs as long as the scanner is in place. Checked all harness connections and paths for damages, nothing.
Car going to the shop today @ 2Pm
Old Jun 23, 2012 | 12:24 PM
Raptor 07's Avatar
Odd. I would suspect some kind of data bus problem since the scanner is using the bus to read your codes. 3rd generation vans are plagued by the instrument cluster cracked solder joint issue. May be the culprit. Smack the dash above the cluster next time it doesn't start.
Old Jun 25, 2012 | 11:17 AM
dlomonaco's Avatar
Default 3.3 resolution
After remaking all of the ground points on the front end of the vehicle, the engine ran. I highly suspected the 10 ga black wire that attaches to the negative battery cable clamp, which does supply the ground for the PCM or cleaning both ground pins on the PCM. Either way, problem solved.
jaydub54
Sep 11, 2008 06:32 PM
ryanb4614
Mar 28, 2008 07:21 AM
Hi_Def
Mar 3, 2008 10:26 AM
Apr 5, 2006 07:13 AM
Feb 1, 2006 01:57 AM
