97 tand c runs fine then shuts off
Old Feb 16, 2013 | 09:01 PM
hals491's Avatar
Default 97 tand c runs fine then shuts off
hi im new 97 town and country,runs fine for 15 min. then stops,have no fire to coil pack,15 min. later runs fine again,any help i would appreciate
Old Feb 16, 2013 | 11:28 PM
codes in the computer?
Old Feb 18, 2013 | 03:20 PM
hals491's Avatar
there are no codes thanks for help,it is a 3.8 motor
Old Feb 18, 2013 | 05:17 PM
Raptor 07's Avatar
If the fuel injectors are dead too that points to an automatic shutdown due to loss of crank or camshaft sensor signal. Could be the sensors themselves, poor connections or the wire harness carrying the signal. If it's only no coil power it points to loss of power out of the PCM meaning a bad wire to the coil, poor connection or a bad PCM.
The OBD fault detect system is far from fool proof. Components often fail without generating a code and a check engine light.
Old Feb 18, 2013 | 10:28 PM
hals491's Avatar
thank you very much, gives me somewhere to start.hopefully i will have some time in the next few days to check it out.
Old Feb 18, 2013 | 10:35 PM
hals491's Avatar
do i have to have noid tester to check pulse at injector connector?
Gringo Starr
Aug 12, 2016 07:37 PM
Nudge
Apr 19, 2015 02:52 PM
eembree
Aug 29, 2009 08:50 AM
cajunsprt
9
Jan 25, 2008 01:06 PM
DJ_Playing
Apr 22, 2006 03:58 PM
